Notifications
Clear all
[Closed] HTTP Backend mixed content problem
2 Users
0 Reactions
(@alanmartin)
Member Admin
Topic starter   [#5]
Hi,
I created a https farm with http backend. If I open the webside some parts of the webside are missed. Error log: block loading from mixed content "http://....".
How can I fix this?
Before I used the SOPHOS WAF with any type of backend.
emiliocm
(@emiliocm)
SKUDONET Engineer Moderator
Good day  @helldunkel, unfortunately, some information is missing in your error explanation. Please explain more about when you experienced this issue and what configuration you applied in the load balancer.
Did you enable WAF in the SKUDONET Load Balancer? The error shared with us "Error log: block loading from mixed content" is present in /var/log/syslog? What request are you sending to the load balancer?
As soon as you extend further information about the issue we will be able to figure out what is going on.
Regards!
emiliocm
(@emiliocm)
Good day, could you share with us more information, please? It is required to figure out what is going on.
Maybe some HTTP Header is missing in the load balancer request to the backend (X-forwarded-Proto: HTTPS) but we need to understand better the issue to figure out what is going on.
Regards!
emiliocm
(@emiliocm)
We will proceed the topic after a few days without any update.
Maybe your load balancing is configured in HTTPS and your backend in HTTP (SSL Offloading) so please check if your application requires X-Forwarded-Proto and X-forwarded-Port, mostly Proto as it seems like your backend is replying the content in HTTP instead of HTTPS. You can add those headers from the Load balancer without concern.
Regards!
Share:
